having problems with power steering after cleaning out pump and replacing hoses. very hard to turn turns easier going right than left.
Also generator getting very hot when engine runs starts smoking!!
I wonder if engine degreaser was the culprit if it got inside generator, should a new unit be put in place of old?
A real PIA system to adjust correctly (am working on one right now). There are adjuster stop nuts on the bell crank (real hard
to see let alone get at) and must have .050" space on each one (spots 'B' and 'C')when steering wheel is centered.
(quoted from post at 12:37:58 07/18/15) having problems with power steering after cleaning out pump and replacing hoses. very hard to turn turns easier going right than left.
ThanksJT inCT
ThanksJT inCT
