While replacing engine had pump off. Was working fine up until it was removed and replaced. Caution was taken to keep dirt out of the open lines. After getting it all back together and topping off the fluid it does not have much pressure or volume. Everything works slow and will not even move much at idle speed. My idea was something was stuck in the main relief valve. Have removed and seen nothing. No change in how it operates. Have drained and checked the suction lines between pump and tank. I don't have a test gauge setup but I would guess the entire system can't make much over 500 psi. I assume the pump is a gear pump with no built in relief valve? Any help on this little puzzle? Thanks, LB
