Implement/Draft Control Selector
Doug (OH)
Hi! My 640 draft control lever is sloppy and hangs down somewhat; however, it will raise the 3-point when I raise the lever. Is there any kind of friction plate or adjustment for the lever? Does anyone have a diagram or cutaway that shows the hydraulic section inside. I found the attached photo but still can't tell much from it. Thanks in advance for your help! Doug
Doug, that lever basically is a toggle, that compresses the position control spring & in doing so, pulls it back from making contact with the control arm which operates the lift valving. This takes position control out of operation & defaults to draft control.
(quoted from post at 19:53:40 07/17/15) Thanks J. So what makes it sloppy and how can I fix it?
can't see under your top cover, but something probably broken, maybe position spring. Going to have to remove top cover to see.
