1900 ford rear end/hyd oil how to check and what oil
jmducks1
1900 ford with loader and 3pt what oil goes
in and how do I check it in the rear end
and hydraulic is it all the same
Compartment? Does it get added by the
transmission shifters? Where is the check
point
can't help you with where, but a UTF meeting ford spec m2c134 will be fine. lots of places to get house brand utf that meets that spec.
the 1900 may have a common sump rear and hyds.. but I don't own one, so whoever tells you 'where', can confirm the sump issue.
The 1900 uses a common sump for the trans, hydraulics and rear axle and if I remember correctly there is a fill plug with a dip stick in the transmission section. Use oil as recomended by soundguy.
Mark
