1964 Ford 2000 leaking
Dean Olson
There's a plug on the left side of the trans housing next to the clutch pedal. It's about 1/2" and takes a flat screw driver to remove. Under it is a spring and a ball.
What is that for? and where do I get a new seal for it?
I'm guessing you don't have a parts manual or service manual, so I went to the NH parts site to look this up for you.
I just generically looked up a 640, but should be the same. the differenc ein other models will be plungers instead of balls.. like my *5* have.
Tried to upload a pdf for you but the board won't take it.
email me and I'll send you the pdf.
or the link I'm posting may work.
E5NN7Z307AA is the 'gasket' or 'seat' depending on where you read the parts info.
cnh site
Manuals ordered and on the way. Tractor is new to me an I'm impatient to get this tractor perfect. I appreciate your help.
