lotsofwork
New User
I need your experience, when i tool over the engine by hand and put it on the the high cam lobe a little bit further it snaps (loud) and jumps to to the low spot on the cam.? remindes me of a mag set up ..this is a front dist. and when it runs can hear the jump over from the dist. area? missing tooth? but it does it with every lobe?
2nd question is on the dist.cap has 1-4 on it so i put no 1 cyl wire in the cap no. 1 is this correct? or should put the on cap in the firing order? it idles ok but there is something going on on full throdel and seems like power is low?
i just need some help that i know someone knows lots more than me thanks mike
