Ford 716B snowblower mounting brackets
caseman46
I have a Ford/Newholland 1530 tractor with 4wd and Supersteer front. This is a compact tractor of about 23 HP. I am looking at a 716B mounted on a Ford/NewHolland 1215 tractor. That tractor is about the same age ( approx. 1995/6) but a series a size smaller. Has anyone made a swap between tractor models? Are the mounting brackets adjustable to fit several models?
Check, carefully, the position of your front wheels, when at full turn! The super steer may not allow clearance for your push frame!
Ran into that very problem when trying to design a push frame for a snow plow on a T4050 with super steer.
I don't know that the smaller tractor would have the same problem, just suggesting that you look into it!
HTH, Dave
Edit: Tractor data lists the 716B blower as an attachment for the 1530, but does not differentiate between super steer and non super steer! Proceed at your own risk!
One on a 1215 or 1220 is only 48" wide, your tractor is 60" wide and takes a larger area when turning with supersteer, I would not spend the time to change it.
