crawdad185
Folks I'll tell you right up front that I have posted this same question on another forum, so I apologize in advance for the redundancy, but I need more help. As the subject says, the Marvel Schebler TSX 765 carb on my tractor is pouring gas out of the air intake. I have taken it apart and soaked and cleaned it as good as I could get it, and then rebuild the carb with one of the comprehensive kits that are over priced. Just as soon as I turn on the gas, the carb will fill up and start pouring out of the air intake. I've now removed and replaced it about 20 times making adjustments and checking the things that some people have suggested. This is what I have done so far: I've made sure the float is good and air tight. I've double and triple checked the float level. I've checked the float drop and made sure it is not touching the sides of the carb. I took the needle and seat back out and I put a small bead of anaerobic sealer around the flange of the seat and reinstalled it. I waited 24 hours for it to cure and then replaced the carb and hooked everything back up. Turned on the gas and within two or three seconds, it started pouring gas out of the air intake.
I don't know what else to do. Has anyone ever dealt with something like this? Any suggestions? Thanks for your help.
