I have a strange problem that I haven't seen in the Forums. I have an 1950 8N and the Hydraulic system is not working correctly. I did find problems with the piston (rings shot) and the pin that is in the Draft control arm (roll pin) which was broken off. I replaced both and now the PTO will stay up even after the tractor is shut off. Before I replaced them the 5ft King Cutter mower would fall in about 2 minutes. The problem I am having now is that when I try to mow, the cutter will not stay in the right height. I also noticed now that the PTO will not go down correctly now. If I try to adjust the height while in gear it I just can't get it to stay. I took everything apart again and found the pin that rides on the cam had a pretty good wear (about a quarter of pin is flat) so I was going to replace that too, but I am not sure that could actually cause that problem. Has anyone else had this problem and what could cause it?
Thanks in advance for any ideas.
