white halftrack
I am going to pick up a tractor I purchased. I need to get it running as it will need to be to load on a trailer. Winch is not an option as it will need to weave through some stuff. Was told it would run but has not run in a while. I have spare parts and am intending to switch out the carb so I don't need to rebuild it and am wondering if it would be easier to have a loaded spare distributor and just switch it. I know on the 4 cylinders the hex rod falls into the oil pan. Is it a bad idea? Would it just be easier to put points in the old one?
Second. Would a 4000 percent carb work on the 3000 engine? Will it run right?
Thanks in advance.
Jason
Thanks in advance.
Jason
