beastlybirdie
A bit back, got an 860 with a 'bad clutch.' It runs good, I've started fixing the previous owner's repairs, and have come to the clutch, which he adjusted, and 'it drove 10 feet and quit). If you push it, there's a grinding and vibration coming through the clutch rod. When engine is off, I can feel the pressure plate engage. And that's for either the first stage or pushing through to the second stage. The input shaft is definitely spinning (the spray out the fill hole was impressive). Cannot put in gear nor engage/disengage pro. If I start it with pro on, that's fine.
So, I guess my question is-stuck clutch, or broken clutch plate? Just looking for opinions, I know how to split it, etc, but looking back at other posts, I see people saying how to unstuck, but not a description of the feel of the pedal.
Thanks for your ideas
