Ring gear torque spec.
Bob2444
New User
Looking to get the torque spec for the ring gear bolts for an APL 325 front axle on a Ford 6610. Thanks all.
I don't have my book in front of me but 50 ft-lb sounds about in range... Don't forget to clean the holes GOOD, with solvent/ether etc until they're DRY, wire brush the bolts, clean in ether, etc and then apply a dab of Loctite 262 (red) to each of them. You do not want them backing out...
A&I will probably have the cheapest supply sources for the hub seal and Fawcett Tractor will beat anyone on the gears, etc.
Rod
