Intake exhausting around injector
Mmhsv
New User
I have a ford 5000 diesel and we replaced the head gasket, and all the injectors. When we got it all put back together, and started cranking we noticed white smoke exhausting around cyl 1 injector. We're thinking it didn't seat right but we haven't pulled it out to check and see yet.
You may have left the copper crush ring out, but even without it it should not let gasses out. The hole may need reaming.
The copper ring was installed but we are starting to think that it didn't seat properly or the ring could be bad if that's possible, it didn't do this before we tore the engine down.
Are the bolts/nut/studs tightening up and not bottoming out making you think they're tight? I've had it happen.
