3000 ford with backhoe and loader oil level check ???
ZANE
Where do you check the oil level in the loader/backhoe on a Ford 3000? Original Ford loader and backhoe.
Also where do you check the oil level for the rear end of the tractor????
Zane
Most likely it has the 730 industrial loader which has a fill plug on top of the left upright and the oil level is measured from the fill hole and if I remember correctly it should be within 11 inches from the top. The rear axle and hydraulic system use the same sump and there is a square head plug on the right side of the housing forward of the rear axle.
Mark
Thanks, I'll check that out.
It's on a friends tractor that I just got through replacing the injection pump with a rebuilt one. Runs great now!
Zane
