INSTALLING REBUILT 3000 INJECTION PUMP?
ZANE
Got the 3000 injection pump rebuilt. Going to install it some time soon.
Need to know if there is any critical timing information I need to know???
It looks like there is no way to get it out of time because the pump shaft is oreinted to the gear with a dowel pin.
Thanks, Zane
Yes, if everything was timed right when the pump was removed and the gears under the front engine cover weren't removed then it should be timed right when it goes back together with the dowel in its alignment hole.
I do scribe a mark where the timing marks are , right at the outer most bolt, that holds the pump. A crooked 1/2 boxed wrench is handy getting the inner bolt loose
Boss
Thanks guys. I've done this on many tractors in the past but my old 80 year old brain is beginning to need refreshed sometimes.
Zane
