On my 4600 the right side, there is a 19 in rod with threads on the one end and it had notches underneath. The original one had broken at the 2nd notch from the end. My tractors front wheels are set almost all the way in. I ordered the new piece, before I had taken the old broken one out of the pipe. Had to heat the pipe with a torch and had a heck of a time getting the old broken shaft out. Now the new shaft wants to bind up going into the pipe, even covered in never seize. Don't want to wait for a new pipe to come since we are in the middle of haying. Question is would it be ok to cut the new shaft off, say as much as 12 in so that I can get back to using the tractor. I can match the number of threads going into the tie rod end to get it pretty close to the original , because I know that how the toe in is adjusted, but any advice about that would be appreciated. Thanks
