Need to change front axle pivot bushing. Two questions. Can you do it without taking off the loader? #2, should I order a new pin or is the pin usually OK?
Thanks for your help. It is slowly coming around. Runs great, couple small hydraulic leaks, PTO clutch stuck, spindle and pivot bushings left to take care of. 200 miles away so only have vacation to work on it or use it to clear lake lot .
