7710 and 7740 loader brackets
How different are the loader brackets for a 83 7710 and a 7740? Found a loader at a junkyard off a 7740. Thinking they should be nearly the same? Here is the listing for the loader. https://www.link_disallowed/Ford-Loader-p/cp-671.htm
I've never got into the specifics of it but I suspect there's a lot of little differences that you might not expect. The mountings to the front bolster, if the loader has them will certainly be different. The middle mounts should have the same bolt patterns... but you have to keep in mind that there are different obstacles that the side rails have to go around on those tractors in mounting to the rear axle. Might be trickier than you first think.
Rod
