961 high crop
???????????? What you saying?? Most 961s are row crop not high crop but no picture hard to see it to know
It was a high crop , it has been molested , the high crop front is good and the rears are gone , I believe the correct 3 point which has a longer lift rods are there , no sheet metal , southern tractor , it is rough no head on block .
Well it don't exist ! But to anyone besides old that is a non believer can I have some help as to where to find the correct rear rims and centers . Thanks for your help.
Unsure of your question? Is this a parts tractor you are selling or need info/parts to repair or maybe you are looking to give it away? There would be a number after the model number stamped on the bellhousing which will indicate the high clearance package.
Kirk
scarce things ain't they?
quick search to see the rears only found me 1 pic...and I can't see the centers.
probably impossible to find original rears but 'adapting'
is always possible.
Pic....looks like 38's on the rear?
welding brackets to some Farmall 38's so the standard Ford centers would bolt up would work.
(had a Super C with 44" tires on the rear with a setup like that)
Maybe Deere 9 hole rims with an adapter plate made up.
good luck
pic
Old, like the rest of us, want to see some pics. Hi crops are seldom seen, and we'd like to see them :)
Boys y'all gonna have to be patient I will get y'all pictures , I need rear centers and rims so I can get it out of the swamp to take pictures so 318-542-0896 will get me if you want to help on this first problem.
Depends on the Massey rim/center some will some will not. If they have the same number of bolts in the center etc good chance they will fit but if a true high crop could run into things not fitting due to the high drop stuff I.E not enough room due to drop centers/bull gears
As old said, some will, some wont. lay some paper over the massey center you have nad rub out the hole spacing, then match it to the ford hub.
I'm running some unknown massey 24" centers on my NAA
