Been baling alot of hay with 3 cyl ford 3000 8 speed for 6 years now and no trouble. Clutch isn't slipping but the pedal doesn't feel like it use to. My question is the triangle clutch disc better ?? I probbaly won't change it until after last cutting but I would like to have a new clutch just in case.I'm half done with first cutting and still have about 1500 to go.Question # 2 I have a 54 naa great tractor 45 lbs oil pressure is it big enough to pull a 275 nh square baler? All I do is bush hogg and rake hay with it.Things are going to good just coming up with a back up.
Thanks for your input
Joe
Joe
