Need Holley carb part for Ford 2000 tractor
MarkP3006
New User
All, I am working a Holley carburetor model C5NN9510L for a 3 cyl. Ford 2000 tractor. While rebuilding it, one of the parts not included in the rebuild kit got mangled. It is the C5NN9N521A which is called out as the "Accelerator Pump Discharge Valve Assy." or part 18A on the illustrated parts breakdown. The part is a small brass tube about an inch long that is threaded and slotted on one end that screws into a portion of the carb casting inside the float bowl. Could not get tube screwed back in after replacing gasket on end of tube. Need to get a replacement part or a junked "parts" carb that still has this component.
Thanks in advance.
Its a one way check valve...
Some things you don't fudge with if it works... Next one you work on if it lets fuel go one way and not the other and the circuit is not restricted don't fudge with it...
I don't have the part but would would like to have one no one has took me up on paying the shipping for a free carb they did not have the ability to fix...
Lock weld it back in with Permatex lock weld ( Epoxy like JB weld) if it checks off like it's spouse too...
Ell I only got 30K in my compatible 4X4 tractor with loader.. It does get'er done tho...
4 more years and $18240.00 and I own it lock stock and barrel...
Whut you waiting on...
A 45 HP 4X4 tractor can tear up a cat 1 implement :(
(quoted from post at 17:47:55 06/06/15) Mark I have one. Will send for shippingcost.
have have been looking for the same thing for the last month and cannot find one wouldnt happen to know where another would be
