All, I am working a Holley carburetor model C5NN9510L for a 3 cyl. Ford 2000 tractor. While rebuilding it, one of the parts not included in the rebuild kit got mangled. It is the C5NN9N521A which is called out as the "Accelerator Pump Discharge Valve Assy." or part 18A on the illustrated parts breakdown. The part is a small brass tube about an inch long that is threaded and slotted on one end that screws into a portion of the carb casting inside the float bowl. Could not get tube screwed back in after replacing gasket on end of tube. Need to get a replacement part or a junked "parts" carb that still has this component.
Thanks in advance.
Thanks in advance.
