SOS shifter
Here is a tip I know I'll probably get fried for passing along since it's not in a manual that I know of. But if your select-o-speed shifter quits shifting check and see if the inner wheel is turning independently of the cast wheel the cable wraps around. If that's the case drill 2 1/8" holes one at 12 and the other at 6 o'clock and drive 2 roll pins in. That will once again lock the two parts together. No over priced manual needed.
