Hello all. Just picked up this sweeeeet 4000 yesterday. The thing runs really well, starting very easily without the use of the manifold heaters. The only imediate issue I see, is a visible leak where the injection pump mounts to the block. Does anyone have any info on an illustrated parts list and/or seal kit for a Dbgvcc429-4c pump?
I've skimmed various forums and came across some people having issues with the umbrella seals that are located on the pump drive shaft. Given the area of the leak, I'm betting that's my problem. I have been monitoring the oil level in the oil pan, and it is slightly over filled (possibly diesel fuel due to leak). I figure someone here has been down this road before, I appreciate any help/info you can provide.
