Marvel Schebler Choke ? NAA ? 600 ?
Ken(Ark)
I have a few extra marvel schebler carb bodys that I am trying to i.d.
Is this a NAA choke , 600 , 700 , ?
Thank You .
Ken I can't say with certainty what it is, but is not like any
of the NAA/640 style carbs I've worked on. 428's etc.
It looks more like one of the TSXU- carbs. Universal fit.
Like this TSXU-833 I did a while back. This one would work
on a MM, Oliver, etc. as the shafts would go in from either side.
Hooking up the choke would be difficult on a Ford, but the cable
holder could be turned 360 degrees to fit basically any tractor
that used a choke cable instead of a choke rod.
That could be part of a carb used on some of the Oliver tractors. All my Oliver's use a choke set up like that
(quoted from post at 02:14:27 06/02/15) I have a few extra marvel schebler carb bodys that I am trying to i.d.
Thank You .
ALLIS CHALMERS TRACTOR CARBURETOR MODEL 170 175 MARVEL SCHEBLER TSX 928 CARB this was on ebay Its difficult to say with only half the bowl there. Looks like Oliver the bracket is on the other side. The fords & MINNEAPOLIS-MOLINE I've seen have a similar bracket but with only 4 single holes not 4 chain drilled holes of 3 each.
