My 660 12v has been running well for several years now. Recently I noticed a miss or slight sputter. It has gotten progressively worse the last few uses. Of note* pulling out choke barely changes anything..hmmm. Pulling each plug wire while running suggested all were firing. Used a separate plug with widened gap and verified spark at each. Points were well worn. Cap and rotor look ok. Disconected fuel line had good flow. Opened petcock under carb; steady stream. Replaced the points (.025). No change. Replaced the plugs just because. They were a bit darker than I prefer but in good shape. No change. Pulled the air breather tube, good suction on hand over carb throat and could have shut it down doing that. Pulled the carb, dismantled, nothing obvious. Float empty. Soaked over night, probed all ports with small wire and jets with torch tip cleaner tool, reassembled, reinstalled; no change. Managed to limp around the fields to spray for corn planting but lacking power and breaking up badly. Tried to check timing but even with hold down ears and bolts removed could not budge the distributor! Even a cold chisel and hammer couldn't move it. Don't know what to do about that. Gave up and picked up a coil on the way home. Beginning to wonder if there's water in the fuel but no sign of any in the sediment bowl. Would really like to free the distributor. What next? I know, buy a new Kubota.
