tex prexhurst
I'm having trouble with my hydraulics. The tractor is a mutt . . . it started out as a SOS, but the tranny was replaced by a 4 speed, so I don't know the exact year. It has 2 levers to the right of the seat, not counting the 3pt control. The 3pt works. One of the levers the inner one, controls a 2way setup which appears to work (the engine labors and the hoses stiffen due to pioneer couplings at the end) It's the other lever, the outer one, that is causing me trouble. I'm trying to set up a snowplow blade in the front. I have a 2 way cylinder. I tried using 2 hoses, the plow would raise but not lower. I then tried a single hose, loosening the allen screw under the front hose as the IT book says. Once again upward pressure, but no allowing the plow to drop. The control valve has 2 ports each on the right and left side. Anyway, does anyone out there have ay ideas.
Thanks,
Tex
Thanks,
Tex
