Hello,
Ol' Rusty is giving me fits with the hydraulics. When I move the touch control lever to raise the hydraulics I get no movement in the arms and dont seem to be getting any pressure to the cylinder though it does sound to be putting more strain on the pump as if it were raising the hitch arms and is pumping fluid to the external valve mounted on the lift cover.
With that being said I will now tell what all I have done so far. I recently overhauled the engine (which runs like a dream) and decided to go through the hydraulics due to it bobbing or hiccuping. I replaced all orings and seals with oem parts including the control valve oring, replaced cam follower pin and rebuilt pump including a new wobble shaft . Originally when I put it back together the arms raised as soon as I started the engine even before I could bleed the system completely so shut it down and pulled the cover to readjust the linkage finding where I had gone wrong the first time. Using the I&T manual I adjusted it again put it back on with the same results so I pulled the cover again and checked the linkage again still in spec but same results.
When I originally had the cover off I completely cleaned the reservoir
I am using premium UTF fluid
Drained the trans to make sure no fluid was getting in the trans..none
Sorry to be so long but I am stumped. Hopefully you guys can think of something I am overlooking.
Thanks in advance
Thanks in advance
