Ford 4600SU Two Spool Remote Hose Replacement
georgmr
New User
My 1976 4600 SU has the optional two spool remote. I want to replace the hoses going to the hydraulic quick disconnects. One hose on each side looks like the normal 1/2" NPT fitting like all the other hoses for the loader, but the other two hoses are crimped to the bolt through block fitting attached to the remote.
Where do I find these block fittings? I've included a photo.
You need the fitting like the bottom one has so you can adapt it to a pipe fitting. The other bugger is something like a hundred bucks or more.. Dealer is about the only source I found for the fittings.
Rod
Please post back if you find a source (especially online) if you find a fitting like the lower one. I've got adapters on adapters for my 545s rear remote. I'd sure like to clean it up. It looks like a banjo to female NPT. I've struck out looking though.
Weatherhead offers the banjo fitting as a U-series crimp fitting which I happen to stock (not a pitch, just a fact). Not nearly $100 in USD. Also avalailable as a female pipe adapter. The photo shows both styles.
The pictured valve is a TISCO valve.
Check with your CNH and/or TISCO dealer.
Either should be able to help you.
Dean
Thanks to everyone for the great feedback.
RickB,
If you have two of the 3/8" NPT adapters for sale, let me know. Otherwise a part number so I can find somewhere to buy these.
I found some other forum posts that reference NH part # 311891 which apparently is a kit with the bolt and necessary washers.
