What is a 7610 supposed to run for boost at full load? It has the pump turned up 1/2 turn. Mine is putting out around 8psi at full load and
no signs of a boost leak anywhere, but I feel like that is a bit on the low side. I always thought 1 psi per 10 hp or so was around normal,
so I would expect this tractor to have closer to 10 psi of boost pressure. I'm measuring at the test port on the intake manifold. It's also
very slow to spool up compared to my Allis with a 301 turbo engine. That motor seems to come to life around 13-1400 rpms, this one seems to
need to be closer to 17 or 1800 rpms to build boost. It's the same tractor I replaced the thermostat in, retimed the injection pump, and
adjusted the valve clearance, all trying to figure out why it falls flat on its face with a load.
Hurst
Hurst
