crawdad185
I recently rescued a Ford 641 from the clutches of a giant oak tree on a fellows farm. He said it had been setting there for about 1 1/2 years. To make a long story short, we drained the tank, put in fresh gas and a good battery and it cranked right up after about 5 spins.
Here is my current problem. The fellow told me it had been converted to 12V and it did have a 12V battery in it. However, it still had the generator on it. The hot wire to the coil was ran around the front of the engine and was spliced in to one of the generator wires. It did crank up and run. Don't know if it was charging or not. Everything else related to the wiring looked to be just like it was originally with the 6V system.
I guess my question is how can I tell if this thing is still wired for a 6 Volt battery or does it sound like a 12 volt battery was thrown in and they called it good? I've been sitting out there in the shop studying the wiring, but the more I look, the more I seem to get confused. I would appreciate any feedback that you guys can give. Thanks
