When I bought the NAA the sheetmetal hood door would bind at the drivers short end or the radiator short end, couldn't find good no bind center by adjusting just one hood hinge (only one hood hinge adjustment screws are freed up for me to adjust with). I'm currently working on the frozen hood hinge adjustment screw pair... heat and soak, heat and soak, hasn't gotten 'em loose yet.
So I removed all of the sheet metal to get at an exhaust elbow gasket leak and remove the gas tank to clean it up and finally stop that sediment bowl leak.
Got both leaks taken care of... now I'm having trouble reinstalling the sheetmetal... looks as if I get the drivers end bolts tight, then I'm well forward of the sheet metal legs big bolt slotted holes and vice versa.
Any suggestions?
-CBull
Any suggestions?
-CBull
