801 Clutch and Pressure Plate
Ready to replace clutch and plate but am confused because clutch measure 10" outside to outside but has 10 splines. Clutch kits advertised show 9" clutch with 10 spline and 10" clutch with 15 spline. Sure grateful for any help.
Thanks, I'm looking at part 8N7963K which specifies 9" clutch disk and plate with 10 splines. If the pressure plate bolt holes line up i'm sure this would be OK but the clutch i removed measures 10".
No scroll all the way to bottom of page in link.
Part No: 1112-5987
Single Clutch Kit - Contains 10 single Pressure Plate NDA7563A, Disc is NCA7550A and measures 10 inch with 10 splines on a 1 3/8 hub. Disc has springs. Also comes with pilot tool, release bearing C0NN7580A and pilot bearing C5NN76500A. For tractor models: 501, 600, 601, 621, 631, 641, 651, 701, 800, 801, 821, 841, 851, 941, 951
