Ford 800 power steering
(quoted from post at 19:05:34 05/18/15) I am in need of an original Power Steering Pump for my Ford 800
One from a 600 or 2000 would work.
Some of the 6x1/8x1 series machines use Eaton pumps, which can be found on '56-64 Ford cars and trucks. Just swap over the reservoir and the pulley. The Eaton pumps I am talking about have the reservoir on the top of the pump casting.
Hope that helps,
Kevin
X2 on the Ford car pumps. A lot of the orphan brands;life Rambler and studebaker used it too. IHC loadstar series trucks in the '60's,'70's used it
on the 304,345 and 392 engines.look for the exposed pump with a bolt on resovoir and the actual pump is the same.same holds forb IHC busses. i've
got dozens from the bus barns.
