I am trying to confirm something I have seen on the TractorData site. If the 63/64 Ford 4000 is continuation of the
800 series and I am told that the 861 is practically identical to the 63/64 Ford 4000. Tractordata shows the 3 point lift capacity
for the Ford 861 at 1250lbs.. while the 1963/1964 Ford 4000 3pt lift capacity is 3200lbs.
Is that right?? If the 8n lift capacity is only 800lbs the 861 is only 450lb more... is that correct ??
