No, but I run them on my 7000 and 7600. My cousin occasionally runs them on his 7710. What specifically do you want to know?
I've never been a fan of rim clamp duals I've always run axle mount. But that is not an option on a 7710. My tractor has non power adjust Any problems holding the lug nuts? I've come to the conclusion that 18.4 34s are enough. I've kicked around using 15.5 38s on the outside.
Both of mine have the cast-center power adjust wheels. No issues. My cousin's 7710 has the steel manual adjust wheels. No issues for him either, although he uses his duals a lot less than I do mine.
I've run T-rails on mine for upwards of 10 years now. No problems with lug nuts. They will eventually split the old 8 bolt/8point centers on those wheels tho.... I've converted mine to the 4 point centers with 8 bolts and no problems since. If you put the tractor in heavy ballast it will amaze you how much more it will pull with a decent set of duals. Completely different tractor. Mind you, mine has been ballasted to close to 14k (with duals) and turned up 20% or more so it's not exactly a basic 7710...
You could at one time get hub duals for them but I wouldn't want them compared to a t-rail.
Rod
