Ford 2000 brakes adjustment
ok I have new shoes on the 2000, the rod that goes from the transmission to the ends of the brake shoes that turn the shoes out to stop you are loose. I took the clevis pin out of the adjustment going to the pedal in hopes of getting some of the twist out of the shaft so it would tighten up ........I just figured out you cannot take up all the twist with the linkage. So if I tighten the brakes with the drum on why does it have so much slop in the shaft that goes between the ends of the brake shoes? I am lost on this. The shaft that goes between the shoes has alot of slop in between the two ends of the brake shoes. Are the shoes the wrong ones? It all looks right except where the rectangle piece goes between the ends of the shoes. why is it so loose?
Does this make sense.........
Scott
