655a fluid change plugs
Ok i got a 655a and want to change all fluids in it. There is a drain on the transmission. Are the trans and rearend seperate or drain both together. If so where is the drain plug on the rearend i dont see it. And as for draining the hydraulics there is a plug on the reservoir but there must be another drain somewhere else correct or no.
This is the best advice you can get.
http://www.ebay.com/itm/ORIGINAL-FORD-655A-TRACTOR-LOADER-BACKHOE-OPERATORS-MANUAL-REAL-NICE-/321440497912?p
