Fordfarmer
Long story short - I have to replace at least some of
the fuel line, and there's a possibility the pump may
not be good. Options are 1) replace as original, 2)
use a low psi electric pump, or 3) gravity feed it.
Would gravity feed work? The inlet on the carb IS
below the fuel tank, but I'm wondering if it will starve
when being worked hard or when the fuel level is
low.
low.
