Ford 1320 Wont move, PTO wont work
A friend of mine brought a Ford 1320 tractor over to my shop for me to check out. I havent had a chance to dig into it yet, but It starts and runs good and the hydraulic lift works, but it will not move in forward or reverse, and the pto wont move. He told me that his dad (the owner) says it sheered a pin in the pto that causes both of these problems. It sounds more like a clutch problem to me though. Ive never had this problem on my ford Powermaster, so not sure where to begin. I am going to try and get a manual for it this weekend. Any one else ever had this problem?
There is no shear pin in that tractor for the transmission and PTO. The problem would have to be with the clutch or transmission input shaft.
Mark
Agree, problem would be clutch or input shaft. IIRC those things don't even have live PTO. Hydraulics work because the pump is engine mounted.
Don't rule out broken gears either. Those things are like a meccano set inside...
Rod
I pulled the top cover off of the transmission over the weekend and everything looks to be moving and engaging as it should so cant be clutch or trans. Has to be something after the transmission. Anyone have a manual and can post a picture of the output shaft on the trans and how it connects to the rear end and pto?
