The Ford 2110 that we are using on the hunting property has developed an issue.
It is leaking from the center bolt where the bell housing meeting the trans housing. This has started recently and when trying to tighten the bolt the housing appears to be stripped.
We took the bolt out and the bolt is not stripped. We added some red rtv to slow down the leak.
My question is this can this housing be drilled and tapped to use a slightly larger bolt or would a heli coil work better. I have tried to use a heli coil if anyone could tell me how they work is this is a possible solution.
The PO added a Kelly frame mounted backhoe attachment. Could this have stripped out the housing as I am thinking that this is creating to much stress on the tractor?
Thanks in advance
Thanks in advance
