I am wondering what the main differences are between these models, am considering a 4630 FWD. I have read the spec sheets on each, but wonder about the front axles, obviously the industrials are heavier, though the hubs look the same and or similar, the AG model has larger diameter front wheels.
Is the 4630 FWD compatible for loader use ? I see many that have them.
What Ford or New Holland loader is correct for a 4630 FWD ? 7310 maybe ? I see woods has a model that fits, but the front part of the frame may block the head lamps.
4630 FWD - 3 pt backhoe, light work, transplant trees, ditch or drainage, would you need a full frame to the loader, something fabricated to fit, or is using it lightly or carefully going to suffice. I don't really know the stress areas on this 4630 chassis, if I had an industrial, I would have to be a 3pt as well, so I could make use of the PTO and 3pt hitch when its not needed.
I may be close to making a deal soon, and am just wanting to insure I've made a good choice if I stay with an ag model. Any comments/opinion?
Thanks for your help.
