Hi guys, thanks for the consistent good advice. This truly is the best place to look for info on old Fords.
I just purchased a 713 backhoe that I plan to mount to my '65 4400. The tractor currently has a FEL driven by a crank powered pump.
I know some valves have power over or a bypass valve, I don't believe mine does though. What would be the best and cheapest way to plumb the hoe to the FEL hydraulics?
Would this work?
It seems like if I plumbed it in like above I wouldn't have to worry about bypass valves, diverter valves or open/closed center though I truly know only what I've read on here.
Advice?
Would this work?
Advice?
