Theoutdoorsman
Just recently purchased this machine, which is the first tractor I've ever owned. I tried to mow with it, but it couldn't cut grass and climb a slight incline simultaneously without stalling out. I checked compression on the "new to me" tractor. All 4 holes look to have relatively even wear, and hovered between 90-95 psi. Would like to have seen slightly higher numbers, but I think there should still be a considerable amount of life left in her. Compression was checked at normal operating temperature, and with the throttle wide open. Oil pressure was at 30# at an idle, 40# at high idle. The previous owner replaced the plugs, distributor cap, and button. I replaced the coil too, just to rule that out. This tractor had sat for just over a year, fully exposed to the elements, without use. I did notice fuel exiting the breather throat of the carb, actually it was running out in a steady stream, which tells me the float was definitely stuck when purchased. I'm sure it needs a good cleaning. I'm off to find a complete carb rebuild kit today. Is there anything I should be aware of prior to removal/cleaning?
