I'm a dummy when it comes to hydralic issues - along with many other things...
My tw20 the main hyd lever suddenly stopped coming out of detent when I lower or raise an implement. It will stay in power down or power up until I flick the lever by hand. It drags the engine down so it is trying to run full pressure, bypass.
It did this on both the field cultivator and the disk, so does not appear to be an implement/ cylinder issue.
All hyd functions work fine, 3pt, the other remote lever works just fine, implements stay up over night, etc.
Only the taller hyd lever is affected, and only the raise or lower detent won't kick out.
So, what happened?
Paul
So, what happened?
Paul
