Well I pulled the pump - it was full of crud and the plungers were stuck but it actually looked in fair shape for wear. It was as if it hasn't had any flow through it for years and just sort-of dried up. I tried blowing air back through the manifold lines - nothing would go through the smaller (high pressure ?) line and only a very little through the larger (return ?) line. Does that sound right? I was expecting basically unrestricted flow through the return line at least.
The following picture is of the top cover: the two missing bolts were in the holes but not tight - it looks like the threads are stripped. What do they do? Are they part of the 3 that you should not remove when you remove the top cover? Could any damage have been done by running it with them loose?
I read about "inspection plates" a lot - is there one for the hydraulic sump? The nearest thing I can think of is the one with the PTO lever on it.
Thanks. phil n
Thanks. phil n
