Greg brown
New User
What should be replaced on ford 3000 power steering?
Issue. Fluid is sprayed out steering wheel and on to driver
Work done.
1. Replaced seal on steering shaft
2. Removed filter
3. Checked each line for blockage
4. Checked pump for blockage. ( at ports / not inside)
5. Checked ports in steering column for blockage
With tank cover off
Observed that the pump is sucking fluid from remote tank and returning through column tube.
The return from pump to tank - no flow ever
Steering/moving tires VERY hard
Work done.
2. Removed filter
With tank cover off
