71 ford 4000 3 cyl diesel 8 speed
I'd rather not pull the cover.
In the past i have had to jiggle/wiggle the hi/lo gear lever on occasion to start the tractor but now that isn't working.
I assume it is broken or stuck since I can bypass it with a jumper wire and start the tractor.
I am using the jumper on the 2 wire connector located about 10 inches after it exits the trans cover.
thks
WJ
thks
WJ
