Leever2000
The electrical system on the 1963 Ford 2000 4cyl gas was a positive ground system meaning the positive terminal on the battery goes to ground. What will happen if the battery is hooked up as a negative ground?
f you didn't replace the cables, too, the size of battery posts & cable end holes ought to make it clear & obvious as to how it was connected before.(quoted from post at 11:19:04 04/25/15) I asked because I had to replace the battery and I took the old out and bought a new and believe it was originally hooked up as a positive ground but had a little doubt so wanted to make sure before completing the hookup of the new battery. Want to make sure it wouldn't be catastrophic. Thanks for the answer Old. I will go ahead and complete the hook up.
ou don't need to clean all the cow poop off of the whole carb to get a number. Just the circled area.(quoted from post at 09:05:52 04/27/15) I hooked up the new battery and all went well. It is positive ground. Now I am back to where I was before (earlier post different thread)
Carberator issues - I put gas in the tractor (about half gallon or less) I start it runs, I let it run until it dies (about 5 to 10 minutes) gas dripping out of the carb. Assume carb needs rebuilt but cannot clean carb good enough to get a part number to order a basic rebuild kit. See picture attached
Recommendations? Thanks
Sound it appears the basic carburetor kit is the same for both the TSX 428 or 580. If I ordered the kit which includes Viton Needle and Seat etc... Once I break down the carburetor I should know if the kit is the correct one?(quoted from post at 08:32:24 04/28/15)
should be like a tsx 428 or 580 for that size engine..
