SteveR(OH)
New User
I bought a tractor that had been converted to 12v, and it started to overcharge the battery.
I was advised the single wire generator has a built in regulator and that was the issue, so I replaced it. Same. Still 14 volts.
Was told to run a ground wire from generator housing to the block, and did that. Same.
Took the generator back to NAPA to have it tested and it tested good. Put it back on.
Ran jumper cable from generator housing directly to the battery. Same
Any suggestions?
Any suggestions?
